Bulldogio
- Apr 7, 2005
- 7
Is it possible to derive the pressure of air flowing through a pipeline from the volume flow rate and the diameter of the pipe. For instance pipe I.D. = 150mm and volume flow rate = 0.3m³/sec.
I have looked at Bernoulli's eqn and the continuity eqn and hence come to the conclusion that the pressure is dependant on the input to the line. I have no other data for this query other than I can tell you the media is air and the pipe is situated in a tunnel.
Please help, for I am getting a little bit frustrated.
