Calorific value for hydrocarbons
Emz80s
Chemical
Jun 7, 2020
8
Hi all
I ask why calorific value for ch4 is higher than all the other ( heavier hydrocarbons) like Ethane , propane ... despite all these heavier HC 'a should have more carbon atoms than ch4 !!
Chemistry.
Write out the reactions, calculate the Free Energy values.
It is a more optimal package.
I ask about the burning of Ch4
Why gives more heat than burning ethane for example ???
Reaction is the burning reaction
CH4 + 2 O2 → CO2 + 2 H2O (ΔH = −891 k J/mol,)
And your point is?
Look at the same for ethane, look at the ratio of CO2:H2O that you get.
And then covert moles to either a volume or a mass and compare.
That is not what I see in Perry Chem Engg Handbook for std. net combustion heat values for methane and ethane:
C1 : 802kJ/gm mol
C2 : 1429kJ/gm mol
Values are based on product H20 in gas phase, while your value for C1 is for water in liquid phase
Maybe the OP is running a condensing boiler and hasn't said so . . . another case of a paucity of information being provided . . .
CR
