jkdmag
Automotive
- Sep 9, 2009
- 40
Interested in experts opinions as to likely source of engine noise that only occurs between gear changes.
My suspicion is that it is cam chain/tensioner noise when the load comes off the engine. It is a thrashing sound that is not noticeable during normal steady state running.
The ALDL data stream also indicates that the ecu is initiating detonation retard at the same time and there are occasions during cruise condition when retard is generated.
There is no audible or ALDL data indication of detonation under any other operating condition.
Could cam chain noise be responsible for a false detonation trigger or maybe the timing shift from poor cam control causes real detonation.
