I am searching for information regarding the design of Cams in mechanical equipment. Specifically, the transfer of forces, torsion requirements ect. The cam I am to design is rotary style similar to what is used for the crank shaft of an automobile. As the cam rotates inside the lobe it will transfer forces and cause linear translation of the body.
