giannitips
- Jul 7, 2011
- 2
Hi to everybody,
I have a CAM question.
I would like to make some drill holes around a cilinder that is parametric generated by his diameter.
Each hole of 1 mm must be 0.25 mm from each other.
When I change the diamater the holes must be ri-calculated every time because they depend on the diamater.
It's possible to do this whitout re-select every time the points for the drill operation?
Thanks.
Thanks.
