HI,
I have a few basic questions in regards to the CAM module of NX6. I am creating toolpaths and verifying them without any problems using the end mills that I have loaded in the pockets. Now I would like to SIMULATE instead of VERIFY my toolpaths, so I proceeded to select my machine as using a Fanuc 3 axis vertical mill controller... no problem up to this point. However when I click simulate, it says there is no tools loaded in the machine. In my "machine tool" view, my tools are all loaded and everything is fine when i verify. Why does it tell me that I cannot simulate because there are no tools loaded in the machine?
Also, I was trying to do "comparisons" between different cutting methods (follow part, zig zag etc...), and so I was hoping I could find the "cutting time" somewhere. Is there a way to find out how long an operation will take to cut? Is this the best method to optimize my programming?
In setting my parameters, I tell NX6 to use 150ipm feedrate but when I verify the animation, it says another feedrate... any thoughts??
Lastly, why does the Fanuc 3 axis vertical mill looks like an horizontal mill and vice versa?
Thank you very much to all.
Max
Max
