CAM: Re-enable warning message 3
JeroenD
Industrial
Jan 21, 2015
13
I recently had a warning message "Motion to Start of Engage" in CAM.
I accidently checked "Don't display this message again" before clicking on OK and now (as expected) the message doesn't show anymore.
I want to re-enable that message but I can't find it.
I presume it's located somewhere within the customer defaults.
If you know something more, please let me know.
Thanks in advance,
Jeroen
I don't believe it's in the Customer Defaults.
I believe it's in Registry key -> HKEY_CURRENT_USER\Software\UNIGRAPHICS SOLUTIONS\NX\9.0\Hide_message
See image below for the hidden warning from my system.
I think if you look at yours you'll find what you're after.
download.aspx
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Thank you both for your response.
I've tried the interface preferences option (registery editor seemed a bit more complicated) and it worked.
Thanks!
Why do I always look for the complicated answer?
Anthony Galante
