I am working on a bracket that holds a 150 pounds shaft that can support rolls that weight up to 2500 pounds.
The shaft is going to be rolling on the cam at variable speed throughout the process, as the rolls become smaller and lighter. (init speed ~ 20 RPM, end speed( smaller roll, light weight) ~ 200 RPM.)
My question consists on the positioning of the cam followers. What angle/position should i position the right cam follower so that the shaft doesnt lift up and hit the marked (GAP) area on the drawing? I tried some stuff but i can't come up to any equation that makes sense to me.
FYI, the shaft is rolling clockwise.
Thank you for your help.
