To me, this original discussion still seems to skirt the edges the first law of thermodynamics, and to my knowledge, that law still stands firm. You cannot get more,
or even equal energy out of any system than what you put into it, no matter how many devices you add to the system to try and recover waste.
Vortex tubes for instance look like really interesting devices that appear to separate thermal energy from moving air, but the fact that is constantly left out of discussions about them is how much energy went into getting the air moving in the first place, and it is tremendous! I once worked on a system to keep a man cool in a foundry area using compressed air into a vortex cooler since the compressed air was already available and electricity was not. Base on the worker producing 2400BTU/hr (heavy work), which equates to about 700 watts, the vortex cooler needed 100cfm at 40 psi. What I discovered is that it took 7-1/2HP of air compressor to get that! So that is 5600W input to extract 700W, a loss ratio of 8:1! Can you design a vortex tube to extract energy from low velocity air movement? I suppose, but it would need to be HUGE!
Ron14, here is what I think you are trying to describe:
You want to put energy into a system in a closed environment to start a generator in one chamber, use the generator to run compressor motors that create a pressure differential between the two chambers, and use air flow between them to keep the generator running after the external power input is removed. In addition, you think you can trap the losses in the generator and compressor motors as heat in that chamber, use the heat to expand air in that chamber, adding to the airflow across the generator. I'm not sure where the vortex tube came into your scheme, but it doesn’t really matter to what I think the issue is. IF you had absolutely perfect, and I do mean
PERFECT sealing and thermal insulation, at the very best, the system could
theoretically sustain itself. The big BUT in this is that absolute insulation and absolute sealing does not, and arguably
cannot exist. So in that scenario any even miniscule amount of energy loss would be essentially sap it of it's own sustenance energy, which would (IMHO) have a logarithmic effect on energy reduction, thus dooming it to rapid failure.
And the bigger question is, WHY? It really is not going to create energy, and you cannot extract any useful energy from it without causing it to rapidly decline, so I doubt that it's storage capability will be any better than any existing system, maybe even worse. On top of it all, it will cost an awful lot to make.
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more." Nikola Tesla
Read the Eng-Tips Site Policies at faq731-376
![[pirate] [pirate] [pirate]](/data/assets/smilies/pirate.gif)
Member, [blue]P
3[/blue]
