Seems to me that the casing would break loose from the cement.
Young's modulus for steel is about 29 x 10**6 psi. If the cross-sectional area of the steel is about 10% of the entire pipe, 15,000 psi in the pipe will produce about 150,000 psi in the steel, which will stretch it about 0.5% ( 1mm for every 200mm of pipe length).
Now assume the pipe is embedded in rigid cement and rock. The cement will shear long before the pipe moves even 1mm, probably at the smooth interface between the steel and the cement. The action will start in a thin band at the edge of the cement near the top of the pipe, and move down quickly.
Am I missing something?
