Can anyone help me on determining the flow rate of argon? 1
haydenle
I am an intern at a steel mill. I very new to this, so bear with me. I currently have a project to size a flowmeter. I know the pressure upstream is around 200psig, this is coming from and Airliquide vessel outside the plant. Down stream we have a pressure regulator and it is regulated down to 80 psig. The headlosses for the system will take forever to determine. The temperature leaving the vessel is -20 degrees F and I am not sure what the temp is at the regulator. Please any help would be greatly appreciated.
oh, forgot to mention...
"I believe it is a gas supply. It is supplied from a 6050 gallon vessel, which then flow through a vaporizer."
If is flows through a vaporizor, then the tank must contain a liquid.
insult
Yes it does contain liquid in the vessel. Are you saying that I could have a two phase mixture on my hands. If pressure and temperature are small and the height doesn't change then, along a stream line it is constant. I still dont know what the velocity upstream or downstream. All I have is:
Outside (at the vessel)
Pressure after the vaporizer: 180 psig
Flow rate at the regulator: 24000 scfm(assumed from 48000/2)
Temp leaving vaporizer: -20 degrees below ambient
Inside (near the purging system)
Pressure regulated down to: 80 psig
Temp( Assuming Ambient): 70 F
Vessel Vaporizer Inside
_____ _ _ _
[ ] || || || (+100ft of piping)
[ ] || || || (elevation change of 15ft)
[ ] ||_||_|| (numerous elbows)
[___ ]---| |---0-----/ /-------0------= exit
P=180psig P=80psig
T=70F T=70F
Q=24000scfh Q=?
After the vaporizer it should be all vapor. I was addressing your application of bournoulli's equation which you were applying from the tank and setting one of the velocities to 0.
Try this:
Point 1:
P_1 = 180 psig T_1 = 70 F z_1 = 15 ft
Point 2:
P_2 = 80 psig T_2 = -20 F z_2 = 0 ft
For conservation of mass, m_dot_1 = m_dot_2; therefore, rho_1*A_1*v_1 = rho_2*A_2*v_2
Assuming A_1 = A_2, then v_1 = v_2*(rho_2/rho_1)
Plug everything into bournoulli:
P_1 + rho_1*{[v_2*(rho_2/rho_1)]^2}/2 + rho_1*g*z_1 = P_2 + rho_2*(v_2^2}/2
Look up or calculate the values for the densities and solve for v_2. Just be careful with units.
insult
Thank you very much. Please excuse my ignorance and lack of experience.
One last question, the velocity to calculate the flowrate, does this mean its acfm or scfm? I am assuming acfm.
OK last answer.
Everything is always acfm, acfm acfm, unless you're writing up a report or selling the stuff. Then its acfm converted to scfm at the sales contract custody transfer conditions.
Going the Big Inch! [worm]
thanks
never assume anything?
insult
you are an insult to injury
correction :you add insult to injury
I am getting 1646 ft/s. Is this number to high?
That number seems a bit larger than expected. I would have expected something much less. Double check your math and units.
Too high. 1646 ft/sec = 1122 miles/hr (Mach 2). Hard to believe 80 psig producing that flow through any significant length piping. The problem isn't entirely defined, but easy to solve if 24000 scf/hr is correct. Simplified calculation using ideal gas law in form V' = (T'/T) x (P/P') x V:
Convert 24000 scf/hr (scf @ 60oF (288.7 K, 14.73 psia) to cf/hr at at 70oF (294.3 K) and 80 psig (94.7 psia):
= (294.3/288.7) x (14.73/94.73) x 24000
= 3804 cf/hr at 70oF (294.3 K) and 80 psig (94.7 psia).
= 1.0567 cf/sec.
A 1" Sch 40 pipe has inside cross-section [π](1.049)2/4 = 0.864 sq. inches = 0.006002 sq. ft.
Hence, linear flow rate
= 1.0567(cf/sec)/0.006002 sq. ft
= 176 ft/sec
Here is how I set up the problem:
P1=(180+14.7)psia
T1=(70+460)R
Z=0
P2=(80+14.7)
T2=(70+460)R
Z2=15 ft
I got the density for the different pressures. Then, like insult said, used convervation of mass to be able to solve for V2.
P1+rho1*(rho2/rho1*V2)^2/2=P2+rho2*V2^2/2+rho2*g*Z2
I also used mathcad to check my calculations. I went through the calcualation several times. I dont see anything wrong, but I could be wrong.
Excuse me, but it seems you are treating the 80 psig regulator as a pressure measured on a piping system.* Unless the upstream portion isn't adequately supplying the regulator to maintain the 80 psig output, it doesn't matter. Could be a 12" diameter pipe at 2000 psi upstream -- doesn't matter.
What is downstream of the 80 psig regulator??
*OK if 80 psig was measured with the regulator valve fully open, with max usage downstream.
WayneLee,
Is the pipe the same dimension at the 180 and 80 psi? If not, the bournoulli simplification won't be right. Also, I just realized that I omitted the head loss term in that equation so don't forget about that. Even without that term though, I don't think it should produce such a high velocity.
