For energy savings, a vfd is replacing the constant speed motor controller for the building hot water pump. Usually, dp switches are installed at the pump output and 2/3rds out into the system. In this case, the line is in a pipe chase that will not allow DP installation on the piping anywhere near the end of the line. The piping is cast iron.
Q1: Can a strap-on flow meter be used at the 2/3rds location? It can be installed since no cutting or welding would be required, but not sure if flow measurement will provide an accurate way to control the pump speed.
Q2: Can DP switches be installed at the pump suction and discharge in lieu of 2/3rds? Will the nearby locations provide enough input on what the system needs really are?
