Hello all,
Can countersunk plugs be used on pressure vessels' small bore nozzles?
I can only find ASME B16.14 covering the countersunk plugs but I can't find it in the referenced standards U-3 of ASME Sec VIII, Div. 1. Does this mean it can't be used on a pressure vessel?
B16.14 is referenced in the piping code (b31.3) though.
I saw one vessel with these plugs on the test ports in my plant and I am wondering if it is out of code requirement and should be replaced with a hex plug per B16.11.
Thanks in advance!
Irwin
Thanks in advance!
Irwin
