Can hydrocad accurately determine
JSiteDznr
18
Can hydrocad accurately determine HGL's?
Thanks!
HydroCAD calculates the water surface elevation at each node in the system and every time step. The maximum WSE at each node is equivalent to the HGL at that point.
Note that an term HGL generally implies a steady-state analysis, with the entire drainage system at equilibrium, while HydroCAD is a hydrograph routing model, where all the WSE's are continuously changing over time. As such, there is no single HGL for the entire system.
Peter Smart
HydroCAD Software
Hi Peter,
Thanks so much for your response. For a typical storm drain network on a road side, would you recommend modeling each catch basin as a detention pond (storage being the actual volume of the concrete catch basin) with a culvert as primary and an overflow weir as secondary for the water that comes out of the grate in larger storm events?
Thanks!
