Greetings,
I am trying to create a circular pattern with sketches, however each time I try I do not get the sketch to pattern around the circle. Basically, I have a disc, with rectangles (3) at 120 degree BC along the outer edge. I am using the sketches for the assembly to use as mate features for the parts. My question is, I can put a single rectangle that is on the outer rim of the disc, but I am not able to have that patterned around the disc. Any ideas, I am probably missing the obvious, so I am asking.
Thanks,
Thanks,
