can i used hydro carbon serive valve istead liquid service valve the valve have same cv
rateb
20
i have fuel control valve 1' reduced bore 3/4" have ascertain cv service fluid is hydro carbon gas
and I have at some where automatic drain valve have same size and bore size service hydro carbon liquid installed and scrubber drain
can I used the first valve instead the second valve the two valve have same size and same cv but different in service media which handling
depends :) Cv is the same but some of the materials in the valve may not be suited.
The design of the control valve is based on the requirements of the process, Press & temp, material, etc. You may gather these conditions and consult with the valve manufacturer.
