The actual trip time? It is a GE PVD Differential Relay.
See the attached (2) pic file of the relay and a cut sheet.
It is connected to a 3000/5 CT, on a 12.47kV bus. The card on the front says it is set at 135V, and 2A.
The cut sheet says its typical operating speed is 20ms (1.2 cycles) at 4X pickup.
Our data from a test report shows that this is set at 0.083 seconds (5 cycles).
