Can two opposing magnets held together by string be stable?
chaimpeck
Computer
Nov 11, 2013
3
I am wondering if I could attach two disc or ring magnets by a string in their center to cause the top one to levitate? Would it be stable or would it flip?
Here is a diagram of what I would like to do.
Thanks.
?? no diagram
However, yes, it will most likely be unstable; is that surprising?
TTFN
faq731-376
7ofakss
The diagram is here:
I am not sure why it is now showing for you.
Is there a way to determine the minimum width of the rings and the distance for it to be stable? Or would it always be unstable?
Has anyone tried this?
You have probably heard of Earnshaw’s theorem which says levitation with magnets is not possible under certain conditions and assumptions. One of the assumptions is no exernal forces, which is violated by your string, so we cannot apply Earnshaw’s theorem.
A little bit of experimentation with two equal size magnets suggests to me that if there is the slightest asymmetry in centering the axis of the two magnets, the magnets experience a moment which tends to flip them.
Can the string provide a reaction moment to prevent flip?
Probably not if it is simply attached from a point in the center of the face of one magnet to a point on center of face of the other magnet. There may be other configurations such as multiple loops of string that might work.
(2B)+(2B)' ?
Oh, that was probably my company's firewall doing its netnanny jig.
One could imagine something that could physically constrain the floating magnet from moving around, like using a rod, instead of a string. If the rod is just slightly undersized from the hole, then there would be little chance of floating magnet from getting out of line
TTFN
faq731-376
7ofakss
Cool, thank you so much for the helpful info. I think a rod (or nail) would work.
I agree with electricpete. Any asymmetry will induce a moment.
Use 2 strings of equal length.
[peace]
Fe (IronX32)
Or three if we are not in a plane..
[peace]
Fe (IronX32)
The configuration must be stable if the string is much shorter than the magnet diameter. Then the remaining question is at what L/D does it become unstable? 1/1?
chaimpeck,
I'm curious, what is this going to be for?
[peace]
Fe (IronX32)
If one magnet id larger than the other is gets easier to do.
A small fiberglass rod would be a good bet.
Plymouth Tube
