GregLocock -"So what advantage do you think they possess over the current solutions?"
Extremely clean exhaust as compare to Otto and Diesel due to low pressure combustion.
1. no catalytic converter necessary
2. no muffler
3. no transmission
4. no starter (to that may be exaction, it have electric burner)
5. no fuel consumption at stop (no idle cycle)
6. up to 3 Hp/lb of engine power weight ratio
7. no visible exhaust (steam, smock..)
8. very quiet operation
9. water last up to 1500miles
10. millage around 15-16MPG
This are list of advantage for car that was design in 1920's
According to Doule the efficiency of used engine was only 16% (in 1916). The only explanation for so good millage is lack of transmission (direct drive).
See what Jay Leno said about that car:
Atalos - your calculation are absolutely correct.
Here is some answer for the acceleration:
"Unlike the internal combustion powered car where the engine provided the horsepower rating for the vehicle, a steam car was rated by it's boiler's steaming capacity. Thus Stanley cars were rated as 10, 20, and 30 horsepower even though a typical 20-horsepower car's steam engine was capable of developing nearly 125 horsepower."
It from:
Here is what Abner Double said in 1916 about the design in discussion:
"E. G. THOMAS:—This paper recalls a conversation with Mr. Doble, in which he contended that multicylinder engines are unnecessary when if steam is used a two-cylinder engine is sufficient. We then rode in his car at speeds varying from 1 to 60 m.p.h. It was a most pleasing sensation. There was absolutely no noise. The car attained any speed desired at any time.
MR. UTICH :—What does the seven-passenger car weigh?
ABNER DOBLE:—A seven-passenger car of 128-in. wheelbase, 56-in. tread front, 57-in. tread rear, equipped with a rather heavy body and 33 by 5-in. wheels weighs 3100 lb., with tank filled ready for the road.
CHAIRMAN ARTHUR J. SCAIFE:—What is the greatest horsepower obtainable with this type of powerplant?
ABNER DOBLE:—The highest normal horsepower that we have used so far is 25, but a 25 hp. steam powerplant at the standard pressure of 600 lb. per sq. in. will exert about 132 hp. for about eight minutes.
S. L. BLACKBURN:—What is the maximum pressure capacity of the boiler?
ABNER DOBLE:—The boiler is designed for a working pressure of 600 lb. The safety valve is set for 1000 lb. The boilers are all tested to 5000 lb. They will rupture at about 8500 to 9000 lb. At this pressure the tubing ruptures at a place remote from the welds. My own car has been in service since December, 1913. The safety valve has never blown. This means that the maximum pressure has never reached 1000 lb."
The link:
There is definitely something to look for in steam power cars. With current technology we definitely can go well beyond 16% of efficiency.
