mechengineer
- Apr 19, 2001
- 265
Hi experts,
The question is that, can we use TEMA to design shell and tube heat exchanger if the design pressure is over 3000 psi?
My understanding is that if the design pressure is higher than 3000 psi (TEMA limit) we can't use TEMA to calculate the tube sheet or any pressured parts. However, it still can use TEMA for structure configuration of the heat exchanger. All pressure parts design shall be as per ASME VIII-1 & VIII-2 if applicable. Am I correct?
Thanks.
Thanks.
