Can you convert this in to sheet metal?
hiyel
Is there any way to convert the following part into sheet metal, or remodel it using sheet metal features? I used some surfacing features to create 5 profiles and then lofted them to get one of the bands, then circular pattern it 3 times. The result is 3 solid bodies. These bands will be water jet cut and rolled, so I need the flattened out view of them.
Any help would be greatly appreciated.
Thanks in advance.
Thanks steinmini. Yes, the bodies are identical, and flattening one will suffice. I did not use the method mentioned on your link. But I came up with another solution that worked. Instead of using 5 rectangular profiles to create one band, I used 2 open loop 3D curves and to make a lofted-bend (I was using one of these curves as the guideline for the 5 profile). In the end, the methods would result in identical bodies, but somehow, only the 2 curve loft method was flattenable.
The point is that you got the desired result. I posted the link because I used that basic procedure for several different problems I had with flattening the bodies that were basically circular. The only "catch" seems to be a "cheat" with not closing the circle to full 360 degrees.
