can you define a line with an equation with Solidworks
mechpins
20
I am trying to sketch a parabolic line with an equation but cant seem to figure it out.
Do you know there's a parabolic sketch feature you can use, similar to a line? You may be better off using that, and then interpreting key points for the parabola to pass through based on your equation.
(If you don't know about the feature I mentioned, search Parabola in Help and it will show you.)
Jeff Mowry
Reason trumps all. And awe transcends reason.
I don't think you can directly. You may want to look into creating a curve through points. You can create a spreadsheet with x,y,z, locations for your parabola. In the excel spreadsheet, you will have your equation(s).
Just a thought.
Shaggy
Thanks for the help I think that I will try to use the excel spreadsheet method. I was asked to use an equation, but I think that I will get good results with the data points.
Thanks guys
parabola equation: y=Ax^2+Bx+C
From this you can determine the focus and apex of the parabola. That should allow you to constrain a parabola according to the equation.
Thanks, Tick--I'd forgotten the simple equation.
Anyway, a parabola is a parabola. Check it out in the sketch and you'll notice you can scale/stretch it to whatever you need. Pin down the focal point and the rest ought to be quite simple.
Jeff Mowry
Be careful as to how you sketch your parabola, that you use a parabola entity and not a spline. Splines have an extra degree of freedom that cause variance. A spline constrained to match a parabola by defining points will never completely match a true parabola, no matter how many defining points are used.
