Can't start a new simulation. WB 11.0 1
Pingen
80
I just installed Ansys WB 11.0.
I can't start a new simulation. The "New simulation" option in the "CAD geometry tasks" list is gray. Although, I can start an existing project containing simulations and access those already existing simulation tabs just fine. What could be causing this problem?
Pingen
Sounds like you're opening it up in read-only mode when you open an existing project.
Double check your license is up to date. All of ANSYS's licenses have a date stamp on them. They allow you to run all ANSYS builds that are dated up to the date stamp. For example, if you have a license that has a date stamp of 1/1/07, you wouldn't be able to run v11 (v11 build date is 1/26/07), but you could run v10 (v10 build date is 1/11/06).
Contact your local ANSYS support provider to have them generate a new license (assuming your TECS is up to date).
Hope this helps,
Doug
