Can't view sketches, what setting will fix it 1
tbinitbini
4
I can't view sketches in one of my part files. All old and all new sketches can only be seen when I am in Sketch mode or when I select the specific sketch in the Feature Manager. The sketches are not set to "hidden".
Whenever I draw a new sketch as soon as I exit Sketch mode the sketch dissappears from view.
What setting to I need to change? This only happens with this one part file. All my other parts and new parts are fine.
I did not create the problem part file. I can see the sketches if I create an assembly and insert the problem part. Why can I see the sketches in my assembly file but not when I open the individual part file?
Thank you in advance for your help
Tbinitbini
When you have the problem part open, check that View > Sketches is selected.
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
Hey thanks, that was quick
The person had selected
View > Hide All Types
Now that I unselected that everything is great.
I tried changing all sorts of settings under Tools > Options but I should have looked under View instead
