justhumm
- May 2, 2003
- 112
I'm looking at a contractor-proposed situation. They need to put a steel shelf angle up on an existing concrete wall. And they need to leave a gap between the wall and the angle. So they're proposing to post-install the anchor, put on a shim pack (steel plates), put up the angle, and tighten it with nuts.
If the shim pack isn't there, the anchor is obviously loaded eccentrically, and it's going to bend and apply a relatively significant tensile load on the anchorage.
Now, if you put the shim pack there, it's going to reduce the deflection, moment, and tension to some extent.
Is anyone aware of an accepted analytical approach (with reference) to showing how much of an effect the shims have?...increasing the effective section / Moment of Inertia of the bolt?...etc?
