overrange
- Jan 7, 2004
- 11
I'm working on a circuit that has the requirement of continuing DC power output after failure of 120VAC input for 2.5 seconds.
The circuit contains a supply that accepts 120VAC and outputs 48 and 24 VDC. The 24V is what needs backup, as it feeds its own loads and supplies the input power to 2 other DC-DC converters, +12VDC and +5VDC. I'm looking into the current requirements now, several hundred watts for 2.5 sec, then shut off by timer.
Has anyone implemented an array of super capacitors to accomplish this successfully? There are some advantages of capacative approach vs lead-acid batteries. We'd need something around 10 - 20 Farads I believe.
Thanks for any suggestions!
Dave at USI
Dave at USI
