We are having a vertical separator of dia 1424mm and height 4790mm . The heads are torispherical. The design pressure is 10 kg/cm2.This separator is planned to be used for separation of crude oil & gas at 6kg/cm2 (operating Pressure). The sp. gravity of crude is 0.8194 abd that of gas is 1.0554(relative to air). Prsently there is no water in the crude.We would like to know the maximum OIL ,WATER and GAS this separator can handle safely with a retention time of approx. 3 minutes . we are also anticipating a water cut of say 90% in next few years . Thus the capacity in terms of only oil,only water and a mixture of 50-50 may be considered .
