bigbadrobby
Industrial
Suffering from a battery that deteriorates after a couple of days of inactivity to the point that it wont crank the engine? It is very hard to determine the battery drain with an inexpensive multimeter. If you try to determine the "resting" discharge current and the car has GPS permanently connected it will often blow the fuse in the multimeter when you connect the multimeter in the earth line (in series). Most inexpensive meters will have a 10 AMP maximum DC current with an internal shunt in the meter. My car is a 2005 Renault Laguna. The GPS appears to be continuously connected,(makes sense as the GPS is always ready to go when you set off, which means that it must draw current when the car is idle).It constantly blew the fuse when I attempted to measure the resting current. Probably due to the surge of current when the battery is connected to live circuits (GPS, memory etc). A lot goes on electricaly when you reconnect a car battery hence the spark.
If you connect the meter to the negative battery connector and connect the other meter lead to the actual battery terminal and carefully remove the battery connector while keeping the connector on the actual battery without disconnecting either wire, you will not get the car re-initialising and possibly blowing the fuse and you can read the steady current discharge rate of your car. I am not certain but from research have found that the resting current should be less than 10ma, some references said it should only be 3ma. Mine was reading 10 times that amount.
So, you need the positive meter lead to the removable negative battery wire and the negative meter lead to the negative battery post before you disconnect the negative terminal from the battery.The meter should be set at 10amp DC current before you start the process (usually a separate meter connection on the meter which will connect internally to the shunt inside the meter). You can then reduce the current setting on the meter to determine the drain.
It would be advisable to have some help when removing the negative connector from the battery as even a momentary disconnection will start the setup routine that happens when you reconnect a battery. You need an uninterrupted connection. So someone keeping the meter prod in contact with the lead negative post of the battery.
Obviously you can use this method for any battery drain problem. If anyone has any other thoughts on this please add to the discussion
....................... well worth a look.
