cmbyrd77
- Aug 4, 2010
- 79
I have a structure that I am designing where the majority of the roof structure is aluminum sections, however the columns are carbon steel. I plan on specifiying that the columns and any carbon steel connection elements be hot dip galvanized. Is there any fastener precautions I need to take to avoid galvanic corrosion? Should I specify stainless steel or aluminum fasteners over galvanized carbon steel fasteners? Thank you very much for the help.
