Reed D
- Oct 30, 2020
- 5
I am currently designing a carport for a friend. I don’t have much experience in structural design as most of my experience is in roadway modeling and construction. I just started studying to take the SE exam (I have my PE in Civil) so when asked if I can design the carport, I figured it will be a good practice. Unfortunately, The more I am digging into this the more I am realizing that I underestimated the complexity of this design
The dimensions of the carport LxWxH = 80’x24’x9’. The carport is open on four sides. I am utilizing ASCE7-10, AISC 14th and IBC2015.
I started with ASCE Sec 27.4.3 (monoslope) for the wind load, IBC table 1607.1 for live load (20 psf) and the dead loads of the materials itself. Then I need to figure the required strength from IBC Sec 1605.2.1 (Load Combination Using Strength Design). Once I figure the required strength I would need to figure the size and locations of the HSS’s (AISC Table 4-3 or table 4-4).
Is this the correct approach? Are there any other loads that I need to account for? Does anyone have a design example for similar carport that can share with me?
Any help would be greatly appreciated.
