We are doing carbursing case hardening on a SAE 8620 material in an Integral/Sealed Quench Furnace using LPG+N2+Methanol atmosphere. The case depth : 1.5-2.4mm, Surface hardness: 58-62HRc.
We are currently facing a problem:
1. Case depth below specs but surface hardness OK
2. Surface hardness varies between 24-59 HRc in same part.
Currently we found one pc each of above problem in one furnace load (1500 pcs)
Following are questions:
1. We have initiated a containment action of eddy current sorting for low case depth. Is this the best method?
2. We are yet to have a containment action for within part variation in HRc. Is there a right method?
3. What could be root causes for this?
SPM
SPM
