bookowski
- Aug 29, 2010
- 983
This is for unreinforced history stone & mass masonry walls. I am looking at a building where a stone failed by splitting. There have been two engineering investigations/reports and they differ in their opinion as to the cause. I've been asked to review both.
Leaving aside their opinions here, I am wondering about the susceptibility to freeze thaw created from the pocket that top anchors create for stone/cast stone facades.
W/out sharing the actual project, I'm talking about anchors similar to the ones shown here: https://masonrymagazine.com/Default?pageID=2252, about 1/4 down the page labeled "mass masonry". This is close enough to what I have (multi wythe brick backup and stone facade).
The top anchors are common in this type of construction. In reviewing this failure, and the opinions, it seems to me that this detail is very likely to have a small pool of water in the anchor pocket. These things are a zillion joints, no way that water isn't getting into at least some of them. Is the idea that ice can expand vertically enough to not typically be a problem? It seems that 99% of the time this is working. In my particular case the stone split right at the anchor. The iron anchor itself shows only surface corrosion, it doesn't appear to be enough that corrosion is what split the stone. If it is freeze thaw I don't see any way to opine on whether or not this would happen at other stones. To me the detail seems inherently problematic in this regard. But I must be missing something because in reality they seem to usually work.
