prost
- Jan 2, 2002
- 583
I have a question about the phrase "cast 7075-T6 aluminum." Every reference I have refers to cast aluminums with designations "AXX.Y", while the wrought aluminum alloys use the 2XXX, 3XXX, etc. designations, with the 'dash' "T-some number" indicating a heat treatment. Does "cast 7075-T6 aluminum" mean an aluminum casting with similar material composition as 7075 with a T6 heat treat, or does it mean the casting has similar mechanical properties of 7075-T6, such as yield, UTS, elongation, etc. Or something else?
