QSubs
Marine/Ocean
- May 27, 2015
- 3
I am designing a number of cast parts using the part copy feature. I model the casting then part copy this part into a new file then cut away the machined surfaces that are required.
When i go to draft the component i specify the material as the casting part number.. Is there any way to do an auto call out to call up the document number of the part that has been part copied?
Andrew
Andrew
