dik
- Apr 13, 2001
- 26,086
This has been posted in the Structural Engineering Forum also:
We have an existing steel structure that is partially submerged. Steel 'S' sections have corroded near the water line by approximately 1/8" over a period of 40 years. Sufficient material remains such that strength is not an issue at this point. We are considering the application of sacrificial zinc strips or 'hockey pucks' to minimize corrosion for the next 40 years. Is this sufficient to provide corrosion resistance and what is the farthest distance from the unprotected surface to the zinc strip is acceptable? Any other method of protection acceptable?
thanks, Dik
thanks, Dik
