Catia edit properties 2
CAD2015
Automotive
Please, see the name of the two bodies in the picture.
I need to replace the non-hybrid Body (in top) with the one below it.
I copied/pasted the Solid.74.
Now, I want to take the final step: to place the same name into the hybrid Body, but Catia doesn't allow me to use the backslash sign.
Is there any way to be able to do this?
CAD 2015
Is there any reason why you must keep that specific name?
It can be done in macro. So, time to code...
I would suggest you to first try to record something, for example search a string like MANIFOLD and then change in properties the MANIFOLD with something else - /MANIFOLD . This will give you an idea what can be done (if something will be recorded.
So, force user to select the body where you want to write / sign, search in selection for a string which appear in all your bodies (I suppose is MANIFOLD), then replace MANIFOLD with /MANIFOLD.
Search also the forum for some examples.
Don't be afraid, some things can be done only with automation, not manually.
Fernando
- Romania
- EU
pKayy,
No, I just wanted to know if it is possible.
Thanks for reply!
Ferdo,
Thanks for your suggestion.
I'll follow your advice.
Regards!
CAD 2015
That's nice to know.......
I've got similar feeling like your........[bigsmile]
CAD 2015
