Catia: Extract Angle parameter value or drive Angle parameter value 1
Mike Dilly
Automotive
Feb 22, 2019
[sub]Hi All,
Is there a way I can extract the value of an Angle parameter and get the numeric value only (not deg) into a Real parameter?
Alternately, I could use the reverse of the above and use the Real parameter to drive the Angle parameter.
I'm using an Angle parameter labeled Bend_Angle
I'm using a Real parameter labeled Angle_of_Bend_for_Formula
My formula is using the Real parameter in the equation
TIA-Mike[/sub]
just divide by the dimension...
10deg/1deg or 13mm/1mm will give you just the numeric value
regards,
LWolf
Thanks Mr. Wolf. I knew it was something like that but it's been so long that I messed with formulas that I forot. I was trying to multiply by 1deg.
