I have a pin that goes through two bushings on the sides of another bushing.
The problem is the pin shoots out of the bushings.
I am able to apply a contact restraint with a clearance on the inner faces of the bushing to the pin.
But, If I try to restrain it the outer face of pin to outer face of bushing with a smooth connection over a general connection with a handler point (located in the center) the stress on the whole assymbly ends up in that location (not realistic).
How should you define a pin you want to stay inside of a bushing for Catia?
