Catia macro BOM to partproperties
Jurchek80
3
SI
Hi all,
I have the following Problem
I try to make a script to extract properties like quantity, positon number,... from BOM(billofmaterial)
and put them to part_properties
I need this data for further processing.
Can you someone help me please?
Thanks a lot
lp jure
tnx to reply ferdo
yes i found this
it is very usefull but i dont know how to extract data for exact part:
Code:
Sub CATMain()
Dim productDocument1 As Document
'Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim assemblyConvertor1 As CATBaseDispatch
Set assemblyConvertor1 = product1.GetItem("BillOfMaterial")
'Dim arrayOfVariantOfBSTR1(7) 'change number if you have more custom columns/array...
'arrayOfVariantOfBSTR1(0) = "Quantity"
'arrayOfVariantOfBSTR1(1) = "Part Number"
'arrayOfVariantOfBSTR1(2) = "Number"
'arrayOfVariantOfBSTR1(3) = "Nomenclature"
'arrayOfVariantOfBSTR1(4) = "Revision"
'arrayOfVariantOfBSTR1(5) = "Mass" 'in addition of what is by default
'arrayOfVariantOfBSTR1(6) = "Density"  'in addition of what is by default
'arrayOfVariantOfBSTR1(7) = "Material"  'in addition of what is by default
'assemblyConvertor1.SetCurrentFormat arrayOfVariantOfBSTR1
Dim arrayOfVariantOfBSTR2(3)  'change number if you have more custom columns/array...
arrayOfVariantOfBSTR2(0) = "Quantity"
arrayOfVariantOfBSTR2(1) = "Part Number"
arrayOfVariantOfBSTR2(2) = "Number"
arrayOfVariantOfBSTR2(3) = "Naziv"
assemblyConvertor1.SetSecondaryFormat arrayOfVariantOfBSTR2
assemblyConvertor1.Print "TXT", "c:\macro\Custom_BOM.txt", product1
Set xlApp = CreateObject("Excel.Application")
Set MyXL = GetObject(, "Excel.Application")
If Err.Number <> 0 Then ExcelWasNotRunning = True
Err.Clear
Set MyXL = GetObject("C:\macro\Book1.xls")
XLApp.Visible = True
Thanks a lot
lp jure
tnx ferdo
yes i need to write data (painted red) from BOM (maybe i can find this data somewhere else) to user defined properties(see picture down)
in ned to put "quantity" to kolicina
and "number" to pozicija
Code:
arrayOfVariantOfBSTR2(0) = [COLOR=#EF2929]"Quantity"[/color]
arrayOfVariantOfBSTR2(2) = [COLOR=#EF2929]"Number"[/color]
regards
jure
