Catia macro: boolean operations -> remove 1
elmundo777
Automotive
Jun 23, 2020
93
0
0
BY
Hi everyone!
I'm interested in the issue of automating boolean operations. There are always two bodies statically. But always different names. How can I assign a button to remove the second body from the first?
What the macro records when executed is not entirely correct. And there is a link to the name of the documents:
Code:
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim shapeFactory1 As ShapeFactory
Set shapeFactory1 = part1.ShapeFactory
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("[b][COLOR=#8AE234]new77777777777777777777777777777777.1\PartBody[/color][/b][i][s][/s][/i]") [COLOR=#EF2929]<--Something universal is needed here. since it is known that the second body is always removed from the first.
and this automatically recorded macro does not work, but only deletes the body.[/color]
shapeFactory1.AddNewRemove body1
part1.Update
End Sub
the first body is always the Mainbody (in you case it is empty)
When you "remove" it removes the body from the active body, which in your case is the Mainbody
Why would you want to remove a body when you do not have geometry yet in the mainbody ?
Eric N.
This is a generated allcatpart from two products. I want to do boolean operations to compare geometry. so all documents will be identical to this.
then you should define the second body as current body and do a remove from the third
Set body1 = bodies1.Item(2)
set body2 = bodies1.Item(3)
part1.InWorkObject = body1
shapeFactory1.AddNewRemove body2
Eric N.
