CATIA Macro measure inertia (mass) only for shown elements
pieswt
9
Hello all,
I have created a macro to measure mass of each part in an Assembly(CatProduct).
The macro is exporting BOM of complete assembly as excel file and then using that BOM to get mass of each part present in the assembly.
The macro is working fine but I noticed that it is measuring mass of hidden bodies/elements too.
Can someone help to modify the macro so that it measures only shown elements?
here's my code:
Code:
Sub CATMain()
    Dim Template As String
    Template = "C:\Users\xyz\Desktop\BOM.xls"  'modify this path
    Dim productDocument1 As ProductDocument
    Set productDocument1 = CATIA.ActiveDocument
    Dim product1 As Product
    Set product1 = productDocument1.Product
    Dim assemblyConvertor1 As AssemblyConvertor
    Set assemblyConvertor1 = product1.GetItem("BillOfMaterial")
    Dim arrayOfVariantOfBSTR1(4)
    arrayOfVariantOfBSTR1(0) = "Quantity"
    arrayOfVariantOfBSTR1(1) = "Part Number"
    arrayOfVariantOfBSTR1(2) = "Type"
    arrayOfVariantOfBSTR1(3) = "Nomenclature"
    arrayOfVariantOfBSTR1(4) = "Revision"
    Set assemblyConvertor1Variant = assemblyConvertor1
    assemblyConvertor1Variant.SetCurrentFormat arrayOfVariantOfBSTR1
    Dim arrayOfVariantOfBSTR2(1)
    arrayOfVariantOfBSTR2(0) = "Quantity"
    arrayOfVariantOfBSTR2(1) = "Part Number"
    assemblyConvertor1Variant.SetSecondaryFormat arrayOfVariantOfBSTR2
    assemblyConvertor1.[Print] "XLS", Template, product1
    MsgBox "Bom Exported Successfully"
    Dim FileSys
    Set FileSys = CATIA.FileSystem
    Dim xlApp
    Set xlApp = CreateObject("Excel.Application")
    Dim mydoc
    Set mydoc = xlApp.workbooks.Open(Template)
    Call Getweight
End Sub
Sub Getweight()
    Dim BOMExcel As Object
    On Error Resume Next
    'if Excel is already running, then get the Excel object
    Set BOMExcel = GetObject(, "Excel.Application")
    If Err.Number <> 0 Then
        'If Excel is not already running, then create a new session of Excel
        Set BOMExcel = CreateObject("Excel.Application")
        BOMExcel.Visible = True
    End If
    'add a new workbook
    BOMExcel.workbooks.Open ("C:\Users\Z0002829\Desktop\Steering Team Macro Support\WIP\BOM.xls")
    Set ws = BOMExcel.ActiveWorkbook.Sheets(1)
    ws.cells(4, 6).Value = "CAD Weight"
    With ws
        Set findrow = .Range("A:A").Find(What:="Recapitulation", LookIn:=xlValues)
    End With
    FindRowNumber = findrow.Row
    For i = 1 To FindRowNumber - 1
            If ws.cells(i, 3).Value = "Part" Then
            PNtoSearch = ws.cells(i, 2).Value
            'measure weight
            Dim oSelection As Selection
            Set oSelection = CATIA.ActiveDocument.Selection
            oSelection.Search "CATAsmSearch.Part.PartNumber=" & PNtoSearch & ",all"
             Dim objProd As Product
              Set objProd = CATIA.ActiveDocument.Selection.Item2(1).Value
              Set objInertia = GetProductInertiaa(objProd)
              If Not (objInertia Is Nothing) Then
                'Retrieve the mass just to show it worked
                'MsgBox objInertia.Mass
                ws.cells(i, 6).Value = objInertia.Mass * 1000
              Else
                MsgBox "The Inertia could not be retrieved!"
              End If
            End If
    Next i
    MsgBox "Weight Exported!"
    ws.SaveAs Filename:="BOM with Weight exproted.xlsx", FileFormat:=xlWorkbookDefault
End Sub
Function GetProductInertia(ByRef iProd As Product) As Inertia
  'If successful, this function will return an inertia object
  'Otherwise, Nothing is returned (you should check the return value)
  Dim objInertia As Inertia
  Set objInertia = iProd.ReferenceProduct.GetTechnologicalObject("Inertia")
  'Set ObjDensity = iProd.ReferenceProduct.GetTechnologicalObject("Density")
  If Err.Number = 0 Then
    Set GetProductInertia = objInertia
  Else
    Set GetProductInertia = Nothing
End If
End Function
thread560-340604
In short, I am searching for how to select "Measure only shown elements" using catvba? as shown in this image:
Thank you for your reply Little Cthulhu.
Selection.VisProperties doesn't solve my issue as there are visible parts having some bodies hiddden.
I want to measure the mass of that part as a whole (but it should not measure the hidden body mass).
there is a setting in tools-options that controls that tick-mark:
General-Parameters and Measure: Measuring Criteria: Measure only shown elements
Once you export settings of this tab, you will be able to deduct how you can toggle it on via script (GetAttr/PutAttr-methods):
Code:
Set settingControllers1 = CATIA.SettingControllers
Set settingRepository1 = settingControllers1.Item("MeasureSettings")
long2 = settingRepository1.GetAttr("MeasureOnlyShownElementsStatus")
' Parameter 1 : (String) "MeasureOnlyShownElementsStatus"
' Returned value : (Variant) (Long) 0
regards,
LWolf
Great, I was looking for this only...
I will modify the macro and test it....
Thank you LWolf!
