Catia Macro Script Help - User Defined Propertes 1
cubygt
Aerospace
Feb 10, 2017
10
Please I need help... I have created the following macros; however, they only work if the product or part is opened up in a separate window. I would like to run a single macro that would these and add the defined properties to every product and part in a assembly.
script for product properties:
Sub CATMain()
Set productdoc = CATIA.ActiveDocument
Set product1 = productdoc.Product
Set parameters1 = product1.UserRefProperties
Set strParam1 = parameters1.CreateString("DRAWING NUMBER", "")
strParam1.ValuateFromString product1.Name & "_SHT_1"
End Sub
script for part properties:
Sub CATMain()
Set partdocument1 = CATIA.ActiveDocument
Set part1 = partdocument1.Part
Set bodies1 = part1.bodies
Set bodyn = bodies1.Item(1)
Set parameters2 = product1.UserRefProperties
Set strParam2 = parameters1.CreateString("MATERIAL/SPECIFICATION", "")
strParam2.ValuateFromString bodyn.Name
End Sub
Thanks...
so check recursive scripting... you might want to include a test if the part/product is already done (in case you have several instances of a part/product)
Eric N.
I had to process a macro of this type, the difference with what you want to do, is that I import the parameters from an Excel file, the macro will loop on all the parts contained in an assembly (active assembly In CATIA), it will also loop on all the subassemblies and parts therein, but the parameters will be written that in the parts, to write parameters in the subassembly it will be necessary to add a procedure as explained right here :
PS: the macro is in VBSCRIPT.
'--------------- MACRO -----------------------
'--------- Extrait Macro Paramètres ----------
'----- JP 2017 -- '------------------------------------------------
Language="VBSCRIPT"
Sub CATMain()
Dim ODocument 'As Document
Dim NbLign 'As Integer
Dim numplan 'As String
Dim design 'As String
Dim fichier 'As String
Dim RefPart 'As String
Dim FichierPath 'As String
Dim LigneExcel 'As Integer
Dim OProduct 'As Product
Dim OParameters 'As Parameters
Dim NouveauDocCatia 'As Documents
Set NouveauDocCatia = CATIA.Documents
Dim ODocuments 'As Documents
Set ODocuments = CATIA.Documents
Dim OPartDocument 'As PartDocument
Dim OstrParam 'As StrParam
Dim PartValue 'As Variant
Dim NbPartValue 'As Integer
Dim NameParam 'As String
Dim Bfichier 'As Boolean
Dim Bnumplan 'As Boolean
Dim Bdesign 'As Boolean
LigneExcel = 1
Set objExcel = CreateObject("Excel.Application")
Dim objSheet
FichierPath =objExcel.GetOpenFilename ("Fichiers Excel (*.xls*),*.xls*")
objExcel.Workbooks.open(FichierPath) 'bon
objExcel.Visible = True
Set objSheet = objExcel.ActiveWorkbook.Worksheets(1)
NbLign = objExcel.Range("A1:X1").CurrentRegion.Rows.Count
For i = 1 To NbLign
LigneExcel = i + 1
fichier = objSheet.Cells(LigneExcel, 1)
numplan = objSheet.Cells(LigneExcel, 2)
design = objSheet.Cells(LigneExcel, 3)
For Each ODocument In ODocuments
Bfichier = False
Bnumplan = False
Bdesign = False
If (InStr(1, ODocument.Name, "CATProduct") > 0) Then
If ODocument.Name = fichier Then
End If
End If
If (InStr(1, ODocument.Name, "CATPart") > 0) Then
Set OPartDocument = NouveauDocCatia.Item(ODocument.Name)
RefPart = OPartDocument.Product.PartNumber
Set OProduct = OPartDocument.GetItem(RefPart)
Set OParameters = OProduct.UserRefProperties
For Each OstrParam In OParameters
PartValue = Split(OstrParam.Name, "\")
NbPartValue = 0
For Each Part In PartValue
NbPartValue = NbPartValue + 1
Next
NameParam = PartValue(NbPartValue - 1)
If NameParam = "fichier" Then
Bfichier = True
If OstrParam.Value = fichier Then
Else
End If
End If
If NameParam = "num_plan" Then
Bnumplan = True
If OstrParam.Value = numplan Then
Else
End If
End If
If NameParam = "design" Then
Bdesign = True
If OstrParam.Value = design Then
Else
End If
End If
Next
If Bfichier = False Then
Set OstrParam = OParameters.CreateString("fichier", (objSheet.Cells(LigneExcel, 1)))
End If
If Bnumplan = False Then
Set OstrParam = OParameters.CreateString("num_plan", (objSheet.Cells(LigneExcel, 2)))
End If
If Bdesign = False Then
Set OstrParam = OParameters.CreateString("design", (objSheet.Cells(LigneExcel, 3)))
End If
Else
End If
End If
next
next
End Sub
All, thanks for your input. I have updated my script shown below. The only issues I am having now is skipping over same part and product instances and being able to use the "partbody" name as an property output. Please advise.
Sub CATMain()
Set strParam1 = parameters1.CreateString("DRAWING NUMBER", product1.PartNumber & "_SHT_1" )
GetNextNode CATIA.ActiveDocument.Product
End Sub
Sub GetNextNode(oCurrentProduct As Product)
Dim oCurrentTreeNode As Product
Dim StrNomenclature, StrDesignation, StrWindows As String
Dim i As Integer
'Loop through every tree node for the current product
For i = 1 To oCurrentProduct.Products.Count
Set oCurrentTreeNode = oCurrentProduct.Products.Item(i)
Set oparameters = oCurrentTreeNode.ReferenceProduct.UserRefProperties
Set oparameters1 = oCurrentTreeNode.ReferenceProduct.UserRefProperties
StrWindows = oCurrentTreeNode.ReferenceProduct.Parent.FullName
On Error Resume Next
'Determine if the current node is a part, product or component
If Right(StrWindows, 4) = "Part" Then
Set oCurrentTreeNode = oCurrentTreePart.Part
Set myBody = myPart.Bodies
Set bodyn = myBody.Item(1)
msgbox bodyn.Name
Set strOparameters = oparameters.CreateString("DRAWING NUMBER", oCurrentTreeNode.PartNumber & "_SHT_1")
Set strOparameters1 = oparameters.CreateString("MATERIAL/SPECIFICATION", "")
ElseIf IsProduct(oCurrentTreeNode) = True Then
Set strOparameters = oparameters.CreateString("DRAWING NUMBER", "")
strOparameters.ValuateFromString oCurrentTreeNode.PartNumber & "_SHT_1"
Else
'MsgBox oCurrentTreeNode.PartNumber & " is a component"
End If
'if sub-nodes exist below the current tree node, call the sub recursively
If oCurrentTreeNode.Products.Count > 0 Then
GetNextNode oCurrentTreeNode
End If
Next
End Sub
Okay I am down to one issue on this macro. Any help is very much appreciated... I am trying to get the partbody name and use in the input for the "MATERIAL/SPECIFICATION" property. See code below. Just to test I have a Msgbox to return the partbody name but It seems no matter what I do it just skips over the code without any errors.
Sub CATMain()
End Sub
Dim oCurrentTreeNodePart As Part
Dim MBod As Body
Dim i As Integer
Set oParameters = oCurrentTreeNode.ReferenceProduct.UserRefProperties
'MsgBox oCurrentTreeNode.PartNumber & " is a part"
While oParameters.Count > 0
oParameters.Remove(1)
Wend
[highlight #FCE94F] Set oCurrentTreeNodePart = CATIA.Document.Add(oCurrentTreeNode).Part
Set MBod = oCurrentTreePart.MainBody
Msgbox MBod.Name[/highlight]
oParameters.CreateString "BOOK FORM INDEX", oCurrentTreeNode.PartNumber & "_SHT_1"
oParameters.CreateString "MATERIAL/SPECIFICATION", ""
Wend
oParameters.CreateString "DRAWING NUMBER", oCurrentTreeNode.PartNumber & "_SHT_1"
Else
End If
End If
Next
End Sub
Code:
will prevent error message.. that's why
Code:
is not giving any error (I have the feeling it could) you could replace it with
Code:
Set oCurrentTreeNodePart = oCurrentTreeNode.Part
and then correct the next line
Code:
Set MBod = oCurrentTree[b]Node[/b]Part.MainBody
I am not checking my code so please excuse me if my typing is not correct...
Eric N.
Okay I removed the "On Error Resume Next" to debug the issue.
And changed lines below:
Set mBody = oCurrentTreeNodePart.MainBody
Msgbox mBody.Name
Now I do get an error "Object doesn't support this property or method:" 'oCurrentTreeNode.Part'. If I put the "On Error Resume Next" back in everything works except these lines. It seems like even though the code loops through all the products and parts it doesn't recognize when it's a part thus not being able to find the partbody name.
Any other suggestions? Again thanks for you response...
Figured it out!!! Finally...
Set oCurrentTreeNodePart = oCurrentTreeNode.ReferenceProduct.Parent.Part
Persistence always pays off [bigsmile]
thanks for sharing
Eric N.
