CATIA macro send to
elmundo777
Automotive
BY
Hello
I want to save a product and parts from tree. But SaveAs saves only a product. How can I save with macro all elements from tree?
I know about CreateSendTo(), but get an error. I'm read in forums, that needs PX1 license. But I'm have only hd2\md2.
This macro also don't work.
Code:
Sub CATMain()
Catia. DisplayFileAlerts = True
Path = CATIA. ActiveDocument.Path
Name = CATIA. ActiveDocument.Name
initial = Path & "A" & Name
Set Folder = CATIA. FileSystem.CreateFolder("oTemp")
oFolder = Path & "OTemp"
Set Send = CATIA. CreateSendTo()
Send.SetInitialFile (initial)     ' HERE I'm get an error
Send.SetDirectoryFile (oFolder)
Send.KeepDirectory(1)
Send.Run
End Sub
You start with the top product and move down to the bottom parts saving everything you see.
The problem is that "SaveAs" affects documents in current session, so you can't really go back to originals until you restart CATIA.
Little Cthulhu said:
Do you have a code or a part of code to demonstrate how i can save everything i see?
I'm really don't know how to do that.
Hi Elmundo777
Why don`t you just use Save Management?
With Save management you can save everything from the tree.
Hi Ferdo,
I guess there is a typo in your reply.
To use SendTo API we need either PX1 license or Smart Team Plugin to Catia.
Or it is better to workaround with the way Little Cthulhu suggessted.
