CATIA MACRO with INPUT SELECTION OPTION to user
DomKum
Automotive
Nov 27, 2005
23
IN
Hi
Below is the macro with input AS POINT and reference PLANE as selected by user, it will create a SKETCH inside which there is predefined CIRCLE.
I will create another SKETCH which is having a PREDEFINED SQUARE in side.
My requirement is when this MACRO is run,
I want MACRO ask user for below two options and based on the selection, sketch has to be created.
1. Sketch with Circle
2. Sketch with SQUARE.
How to go forward this using input options.
Please share your thoughts. Thanks in advance
PS: Please share link for MACROS in which INPUT BOX is used for allowing the user to selection options available in macro.
Language="VBSCRIPT"
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1 = partDocument1.Part
Set hybridBodies1 = part1.HybridBodies
'----->with below line the Sketch will always be created in GS1.
'Set hybridBody1 = hybridBodies1.Item("Open_body.1")
'---->>> with below line sketch will always be created in acitve GS
Set hybridBody1 = CATIA.ActiveDocument.Part.InWorkObject
Msgbox("Pickup the reference plane for sketch")
Dim InputObjectType(0), Status1
Set selection1 = partDocument1.Selection
selection1.Clear
InputObjectType(0)="Plane"
Status1=selection1.SelectElement2(InputObjectType,"Select plane",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Set reference1 = selection1.Item(1).Reference
MsgBox reference1.Name
Msgbox("Pickup the reference point to sketch reference")
InputObjectType(0)="Point"
Status1=selection1.SelectElement2(InputObjectType,"Reference point",false)
Set reference2 = selection1.Item(1).Reference
MsgBox reference2.Name
Set sketches1 = hybridBody1.HybridSketches
'-----Created by default macro recording---
'Set sketch1 = sketches1.Item("Sketch.1")
'Set sketch1 = body1.Sketches
Set originElements1 = part1.OriginElements
Set sketch1 = sketches1.Add(reference1)
'Set sketch1 = originElements1.reference1
part1.InWorkObject = sketch1
Set factory2D1 = sketch1.OpenEdition()
Set geometricElements1 = sketch1.GeometricElements
Set axis2D1 = geometricElements1.Item("AbsoluteAxis")
Set line2D1 = axis2D1.GetItem("HDirection")
line2D1.ReportName = 1
Set line2D2 = axis2D1.GetItem("VDirection")
line2D2.ReportName = 2
Set point2D1 = factory2D1.CreatePoint(10.000000, 10.000000)
point2D1.ReportName = 3
Set circle2D1 = factory2D1.CreateClosedCircle(10.000000, 10.000000, 4.000000)
circle2D1.CenterPoint = point2D1
circle2D1.ReportName = 4
Set constraints1 = sketch1.Constraints
Set reference1 = part1.CreateReferenceFromObject(circle2D1)
Set constraint1 = constraints1.AddMonoEltCst(catCstTypeRadius, reference1)
constraint1.Mode = catCstModeDrivingDimension
Set length1 = constraint1.Dimension
length1.Value = 4.000000
Set reference2 = part1.CreateReferenceFromObject(line2D1)
Set reference3 = part1.CreateReferenceFromObject(point2D1)
Set constraint2 = constraints1.AddBiEltCst(catCstTypeDistance, reference2, reference3)
constraint2.Mode = catCstModeDrivingDimension
Set length2 = constraint2.Dimension
length2.Value = 10.000000
Set reference4 = part1.CreateReferenceFromObject(line2D2)
Set reference5 = part1.CreateReferenceFromObject(point2D1)
Set constraint3 = constraints1.AddBiEltCst(catCstTypeDistance, reference4, reference5)
constraint3.Mode = catCstModeDrivingDimension
Set length3 = constraint3.Dimension
length3.Value = 10.000000
sketch1.CloseEdition
part1.InWorkObject = hybridBody1
part1.UpdateObject sketch1
part1.Update
End Sub
"input box" - google - pick any link
Done in 3 seconds.
Respect forum members, save their time.
Questions about general programming is not what we here for.
Hi All,
Finally I could able to make MACRO with selection 1.Circle or 2.Rectangle.
I would be more happy for me if this will be useful to any new beginners like me.
My next step is to create PAD from it. Hope it works.
Language="VBSCRIPT"
Sub CATMain()
MsgBox ("This Macro is to create sketch for Circle or Rectangle")
selection1.Clear
'Dim Choice ' ' As Integer
Choice = InputBox("Please Select 1 for Circle or 2 for Rectangle")
' - - - - - > > > > > ----- Circle Strart - -- - - - - - - - - - - - - -
If Choice = 1 Then
' - - - - - > > > > > ----- Circle End - -- - - - - - - - - - - - - -
Else Choice = 2
'MsgBox " You selecion is " & 2
' - - - - - > > > > > ----- Rectangle Start - -- - - - - - - - - - - - - -
'Set sketch1 = sketches1.Item("Sketch.5")
'part1.InWorkObject = sketch1
Set point2D1 = factory2D1.CreatePoint(15.000000, 40.000000)
Set point2D2 = factory2D1.CreatePoint(65.000000, 40.000000)
point2D2.ReportName = 4
Set line2D3 = factory2D1.CreateLine(15.000000, 40.000000, 65.000000, 40.000000)
line2D3.ReportName = 5
line2D3.StartPoint = point2D1
line2D3.EndPoint = point2D2
Set point2D3 = factory2D1.CreatePoint(65.000000, 15.000000)
point2D3.ReportName = 6
Set line2D4 = factory2D1.CreateLine(65.000000, 40.000000, 65.000000, 15.000000)
line2D4.ReportName = 7
line2D4.EndPoint = point2D2
line2D4.StartPoint = point2D3
Set point2D4 = factory2D1.CreatePoint(15.000000, 15.000000)
point2D4.ReportName = 8
Set line2D5 = factory2D1.CreateLine(65.000000, 15.000000, 15.000000, 15.000000)
line2D5.ReportName = 9
line2D5.StartPoint = point2D3
line2D5.EndPoint = point2D4
Set line2D6 = factory2D1.CreateLine(15.000000, 15.000000, 15.000000, 40.000000)
line2D6.ReportName = 10
line2D6.EndPoint = point2D4
line2D6.StartPoint = point2D1
Set reference1 = part1.CreateReferenceFromObject(line2D3)
Set constraint1 = constraints1.AddBiEltCst(catCstTypeHorizontality, reference1, reference2)
Set reference3 = part1.CreateReferenceFromObject(line2D5)
Set reference4 = part1.CreateReferenceFromObject(line2D1)
Set constraint2 = constraints1.AddBiEltCst(catCstTypeHorizontality, reference3, reference4)
Set reference5 = part1.CreateReferenceFromObject(line2D4)
Set reference6 = part1.CreateReferenceFromObject(line2D2)
Set constraint3 = constraints1.AddBiEltCst(catCstTypeVerticality, reference5, reference6)
Set reference7 = part1.CreateReferenceFromObject(line2D6)
Set reference8 = part1.CreateReferenceFromObject(line2D2)
Set constraint4 = constraints1.AddBiEltCst(catCstTypeVerticality, reference7, reference8)
constraint4.Mode = catCstModeDrivingDimension
Set reference9 = part1.CreateReferenceFromObject(line2D1)
Set reference10 = part1.CreateReferenceFromObject(line2D5)
Set constraint5 = constraints1.AddBiEltCst(catCstTypeDistance, reference9, reference10)
constraint5.Mode = catCstModeDrivingDimension
Set length1 = constraint5.Dimension
length1.Value = 15.000000
Set reference11 = part1.CreateReferenceFromObject(line2D2)
Set reference12 = part1.CreateReferenceFromObject(line2D6)
Set constraint6 = constraints1.AddBiEltCst(catCstTypeDistance, reference11, reference12)
constraint6.Mode = catCstModeDrivingDimension
Set length2 = constraint6.Dimension
length2.Value = 15.000000
Set reference13 = part1.CreateReferenceFromObject(line2D4)
Set constraint7 = constraints1.AddMonoEltCst(catCstTypeLength, reference13)
constraint7.Mode = catCstModeDrivingDimension
Set length3 = constraint7.Dimension
length3.Value = 25.000000
Set reference14 = part1.CreateReferenceFromObject(line2D6)
Set reference15 = part1.CreateReferenceFromObject(line2D4)
Set constraint8 = constraints1.AddBiEltCst(catCstTypeDistance, reference14, reference15)
constraint8.Mode = catCstModeDrivingDimension
Set length4 = constraint8.Dimension
length4.Value = 50.000000
End if
part1.Update
End Sub
Hi
This macro is with creation of PAD.
Hope this will be useful for new beginners
Language="VBSCRIPT"
Sub CATMain()
selection1.Clear
If Choice = 1 Then
Else Choice = 2
part1.Update
End if
' - - - - - > > > > > ----- Rectangle End - -- - - - - - - - - - - - - -
' - - - - - This line was created for testing -- working fine----
'If Choice = 1 Then
'MsgBox ("Your Selection is " & 1 & " - Circle")
'Else
'MsgBox ("Your Selection is " & 2 & " - Rectangle")
'End if
'--------- This is for testing only --------
' - - - - - Creation of PAD from the sketch above
PAD = Msgbox("Do you want to create PAD" , vbYesNo+vbQuestion, "Tell me")
If PAD = vbYes Then
'Msgbox "PAD"
Set bodies1 = part1.Bodies
Set body1 = bodies1.Add()
part1.InWorkObject = body1
Set shapeFactory1 = part1.ShapeFactory
Set reference1 = part1.CreateReferenceFromName("")
Set pad1 = shapeFactory1.AddNewPadFromRef(reference1, 20.000000)
'Set hybridBody1 = hybridBodies1.Item("Geometrical Set.3")
'Set sketch1 = sketches1.Item("Sketch.22")
Set reference2 = part1.CreateReferenceFromObject(sketch1)
pad1.SetProfileElement reference2
pad1.IsSymmetric = True
part1.UpdateObject pad1
Else
MsgBox " Thank you for using this macro"
End if
part1.Update
End Sub
