CATIA shows runtime Exception Error after created new CATSetting folder in %AppData%
siddhu2310
7
I'm using multiple version of CATIA,
setting are collapse frequently, so I have changed the CAT setting path inside the :C:\ProgramData\DassaultSystemes\CATEnv
Now new setting folder are created but, when try open Option > Setting > Drafting, it gives error.
I could not able to open the existing drawing as well,
even i tried to copied old setting files to new setting files folder.
Not working
 https://files.engineering.com/getfile.aspx?folder=50e7f6c0-0145-4fe6-a96c-f9595271a7b4&file=error.log
I resolved the issue by restoring the config files with proper permissions in the below location.
C:\ProgramData\DassaultSystemes\CATEnv\
