Nov 20, 2020 #1 jackk Mechanical Nov 22, 2002 1,306 0 0 US Can someone share the xml file for INCH threads, or tell me where to find a file to copy. thanks, Jack
Nov 29, 2020 #2 weagan22 Aerospace Aug 27, 2015 79 0 6 US <?xml version="1.0" ?> <std:node name="UnifiesInchScrDecimalSizes" type="Thread_standard" xmlns:std="http://www.dsweb.com/std"> <std:typedef name="Standard"> <std:floatval name="ThreadDiameter" >0.</std:floatval> <std:floatval name="Pitch" >1.</std:floatval> <std:floatval name="NominalDiameter" >0.13</std:floatval> <std:strval name="Description" >M8</std:strval> </std:typedef> <std:node name="Key"> <std:strval name="KeyDrafting" >M</std:strval> <std:strval name="KeyDrafting" >NO_DESC_IN_DRAFTING</std:strval> </std:node> <std:node name="Unit"> <std:strval name="Unit" >in</std:strval> </std:node> <std:node name="Values"> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.25</std:floatval> <std:floatval name="Pitch" >5.e-2</std:floatval> <std:floatval name="NominalDiameter" >0.201</std:floatval> <std:strval name="Description" >1/4-20 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.25</std:floatval> <std:floatval name="Pitch" >3.5714e-2</std:floatval> <std:floatval name="NominalDiameter" >0.213</std:floatval> <std:strval name="Description" >1/4-28 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.3125</std:floatval> <std:floatval name="Pitch" >5.5556e-2</std:floatval> <std:floatval name="NominalDiameter" >0.257</std:floatval> <std:strval name="Description" >5/16-18 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.3125</std:floatval> <std:floatval name="Pitch" >4.1667e-2</std:floatval> <std:floatval name="NominalDiameter" >0.272</std:floatval> <std:strval name="Description" >5/16-24 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.375</std:floatval> <std:floatval name="Pitch" >6.25e-2</std:floatval> <std:floatval name="NominalDiameter" >0.3125</std:floatval> <std:strval name="Description" >3/8-16 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.375</std:floatval> <std:floatval name="Pitch" >4.1667e-2</std:floatval> <std:floatval name="NominalDiameter" >0.332</std:floatval> <std:strval name="Description" >3/8-24 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.4375</std:floatval> <std:floatval name="Pitch" >7.1428e-2</std:floatval> <std:floatval name="NominalDiameter" >0.368</std:floatval> <std:strval name="Description" >7/16-14 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.4375</std:floatval> <std:floatval name="Pitch" >5.e-2</std:floatval> <std:floatval name="NominalDiameter" >0.390625</std:floatval> <std:strval name="Description" >7/16-20 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.5</std:floatval> <std:floatval name="Pitch" >7.6923e-2</std:floatval> <std:floatval name="NominalDiameter" >0.421875</std:floatval> <std:strval name="Description" >1/2-13 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.5</std:floatval> <std:floatval name="Pitch" >5.e-2</std:floatval> <std:floatval name="NominalDiameter" >0.453125</std:floatval> <std:strval name="Description" >1/2-20 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.5625</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >0.484375</std:floatval> <std:strval name="Description" >9/16-12 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.5625</std:floatval> <std:floatval name="Pitch" >5.5556e-2</std:floatval> <std:floatval name="NominalDiameter" >0.515625</std:floatval> <std:strval name="Description" >9/16-18 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.625</std:floatval> <std:floatval name="Pitch" >9.0909e-2</std:floatval> <std:floatval name="NominalDiameter" >0.53125</std:floatval> <std:strval name="Description" >5/8-11 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.625</std:floatval> <std:floatval name="Pitch" >5.5556e-2</std:floatval> <std:floatval name="NominalDiameter" >0.578125</std:floatval> <std:strval name="Description" >5/8-18 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.75</std:floatval> <std:floatval name="Pitch" >0.1</std:floatval> <std:floatval name="NominalDiameter" >0.65625</std:floatval> <std:strval name="Description" >3/4-10 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.75</std:floatval> <std:floatval name="Pitch" >6.25e-2</std:floatval> <std:floatval name="NominalDiameter" >0.6875</std:floatval> <std:strval name="Description" >3/4-16 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.875</std:floatval> <std:floatval name="Pitch" >0.111111</std:floatval> <std:floatval name="NominalDiameter" >0.756625</std:floatval> <std:strval name="Description" >7/8-9 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >0.875</std:floatval> <std:floatval name="Pitch" >7.1428e-2</std:floatval> <std:floatval name="NominalDiameter" >0.8125</std:floatval> <std:strval name="Description" >7/8-14 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.</std:floatval> <std:floatval name="Pitch" >0.125</std:floatval> <std:floatval name="NominalDiameter" >0.875</std:floatval> <std:strval name="Description" >1-8 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >0.921875</std:floatval> <std:strval name="Description" >1-12 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.</std:floatval> <std:floatval name="Pitch" >7.1428e-2</std:floatval> <std:floatval name="NominalDiameter" >0.9375</std:floatval> <std:strval name="Description" >1-14 UNS</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.125</std:floatval> <std:floatval name="Pitch" >0.142857</std:floatval> <std:floatval name="NominalDiameter" >0.984375</std:floatval> <std:strval name="Description" >1 1/8-7 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.125</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >1.046875</std:floatval> <std:strval name="Description" >1 1/8-12 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.25</std:floatval> <std:floatval name="Pitch" >0.142857</std:floatval> <std:floatval name="NominalDiameter" >1.109375</std:floatval> <std:strval name="Description" >1 1/4-7 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.25</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >1.171875</std:floatval> <std:strval name="Description" >1 1/4-12 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.375</std:floatval> <std:floatval name="Pitch" >0.166667</std:floatval> <std:floatval name="NominalDiameter" >1.21875</std:floatval> <std:strval name="Description" >1 3/8-6 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.375</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >1.296875</std:floatval> <std:strval name="Description" >1 3/8-12 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.5</std:floatval> <std:floatval name="Pitch" >0.166667</std:floatval> <std:floatval name="NominalDiameter" >1.34375</std:floatval> <std:strval name="Description" >1 1/2-6 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.5</std:floatval> <std:floatval name="Pitch" >8.3333e-2</std:floatval> <std:floatval name="NominalDiameter" >1.421875</std:floatval> <std:strval name="Description" >1 1/2-12 UNF</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >1.75</std:floatval> <std:floatval name="Pitch" >0.2</std:floatval> <std:floatval name="NominalDiameter" >1.546875</std:floatval> <std:strval name="Description" >1 3/4-5 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >2.</std:floatval> <std:floatval name="Pitch" >0.222222</std:floatval> <std:floatval name="NominalDiameter" >1.78125</std:floatval> <std:strval name="Description" >2-4 1/2 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >2.25</std:floatval> <std:floatval name="Pitch" >0.222222</std:floatval> <std:floatval name="NominalDiameter" >2.03125</std:floatval> <std:strval name="Description" >2 1/4-4 1/2 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >2.5</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >2.25</std:floatval> <std:strval name="Description" >2 1/2-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >2.75</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >2.5</std:floatval> <std:strval name="Description" >2 3/4-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >3.</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >2.75</std:floatval> <std:strval name="Description" >3-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >3.25</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >3.</std:floatval> <std:strval name="Description" >3 1/4-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >3.5</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >3.25</std:floatval> <std:strval name="Description" >3 1/2-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >3.75</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >3.5</std:floatval> <std:strval name="Description" >3 3/4-4 UNC</std:strval> </std:typeval> <std:typeval name="Standard"> <std:floatval name="ThreadDiameter" >4.</std:floatval> <std:floatval name="Pitch" >0.25</std:floatval> <std:floatval name="NominalDiameter" >3.75</std:floatval> <std:strval name="Description" >4-4 UNC</std:strval> </std:typeval> </std:node> </std:node> Upvote 0 Downvote
Dec 1, 2020 Thread starter #3 jackk Mechanical Nov 22, 2002 1,306 0 0 US thanks Weagan22 Upvote 0 Downvote
