Catia V5 not displaying Catparts just tree 2
DuckyB
Aerospace
May 22, 2012
20
My co-workers install only shows catproducts geo but not catparts geo. When a catpart is opened only the tree is displayed and reframing on the solid does nothing. When a catpart is open and the “fit all in” button is pushed only the tree gets bigger and NO part is displayed.
Does anyone have a idea what could be causing this to happen?
Sounds like the tree is active, and not the graphics. Click on the little axis in the lower-right corner of the window to activate the graphics, and try the Fit-Al-In button again.
Jack the "little axis in the lower-right corner" does not appears with catpart. As soon as catpart opens the axis disapears. Any other ideas?
try clicking on any tiny horizontal line on model tree.
Both Clicking on the Axis or Clicking a Line of part of the tree will switch between tree being active or geometry.
You can also Hold Shift + Press F3 on the keyboard to swap between Geometry/Tree active.
Unspoken, Shift + Press F3 worked.
Thank you
