Catia V5 Rename Partnumbers of Bodies by UserForm 1
us01
New member
Oct 29, 2012
14
First of All, i'd like to thank the person who helped me last time, due to him, i had improuved my Catia Level (sadly, not in english ..)
So i'finish my code, but it still not working, i mean, it fonction but not fully. Can anyone have a look on my code and tell me my errors ?
This userform helps me to fill the proprietes of Bodies
Thx Everyone
Best Regards
Here is my UserFormInterface
- I named the boxes as "TextBox1", "TextBox2", "TextBox3"
here is my code :
Code:
Sub CATMain()
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Add("Part")
Set part1 = partDocument1.Part
Set bodies1 = part1.Bodies
Set body1 = bodies1.Add()
part1.Update
Set body2 = bodies1.Add()
part1.Update
Set body3 = bodies1.Add()
part1.Update
Set body4 = bodies1.Add()
part1.Update
Set product1 = partDocument1.GetItem("Part1")
strPath = "H:\VBA\Project\ProjetVBA1.catvba"
strModule = "modMain"
strProcedure = "CATMain"
UserForm1.Show 0
UserForm1.TextBox1.Value
If UserForm1.TextBox1.Text = "" And _
   UserForm1.TextBox2.Text = "" And _
   UserForm1.TextBox3.Text = "" And _
   UserForm1.TextBox4.Text = "" Then
Else
End If
End Sub
In the picture attached is the body feature properties (right mouse button click on body).
Where do you want to fill those properties ? Did you tried to do it manually first ? Do you want to create some parameters under body or ?
As I remember, Eric recommend you to do a single part1.Update not each time (but this is not the main problem as I can see).
Fernando
I can do it manually, but i want to made a macro, when i click on it, the "userform" will appear, and i should fill the blanks on the macro and thats will made me 5 "bodies" with the name that i have filled in the "textbox".
Exactly sir, i just want to rename the new bodies names with a VBA And later if i understand the right working way of macro, i'll add a "line" to catalogue of materials ! But i'm not there ! first of all, i want to rename new bodies
