CATIA V5 VBA Code Efficiency Renumbering Constraints 1
AeroTD
Aerospace
Feb 25, 2022
4
I know the following is NOT the most efficient method but I'm having a hard time finalizing the code even though I'm sure it's simple enough. I would appreciate 1. some feedback to eliminate the specific text (eg: Fix., Coincidence., Offset.) with a variable 2. I've had success calling the renumbering code as a sub routine but pulled it out for testing.
Option Explicit
Sub CATMain()
Dim osel As Selection
Dim i As Integer
Set osel = CATIA.ActiveDocument.Selection
osel.Search "(Name='Fix.*' & CATAsmSearch.MfConstraint),in"
For i = 1 To osel.Count
osel.Item(i).Value.Name = "Fix." & i
Next 'i
osel.Clear
osel.Search "(Name='Coincidence.*' & CATAsmSearch.MfConstraint),in"
osel.Item(i).Value.Name = "Coincidence." & i
Next 'i
osel.Clear
osel.Search "(Name='Offset.*' & CATAsmSearch.MfConstraint),in"
osel.Item(i).Value.Name = "Offset." & i
Next 'i
osel.Clear
End Sub
Thank you!
Do you really need to differentiate between different type of constraints? Can't you just use a single oSel.Search "CATAsmSearch.MfConstraint,all" search call to renumber all constraints at once?
I'm open to selecting all the constraints, BUT then I need assistance to search the string only to the character "." and remove anything after. The current code would result in "Fix.11" versus "Fix.1". Easy in excel, but not so much in CATIA.
Use [tt]Split(name, ".")[/tt] and extract first part from the result:
Code:
Option Explicit
Sub CATMain()
  CATIA.HSOSynchronized = false
  osel.Search "CATAsmSearch.MfConstraint,in"
  Dim i As Integer
    osel.Item(i).Value.Name = Split(osel.Item(i).Value.Name, ".")(0) + CStr(i)
  Next
  osel.Clear
  CATIA.HSOSynchronized = true
End Sub
Thank you! I was trying to use "InStr" with no success.
To complete the script, I updated to add the "." back into the name:
Code:
Sub CATMain()
  CATIA.HSOSynchronized = False
  Dim i As Integer
    osel.Item(i).Value.Name = Split(osel.Item(i).Value.Name, ".")(0) + "." & CStr(i)
  Next
  osel.Clear
  CATIA.HSOSynchronized = True
End Sub
