One smart way to to it (and also dynamic) is to make a separate parametric part with some sketches containing just a line, exactly as you would do in drafting. You need to make this part and the sketches inside parametric so the lines always move with the parts of interest in your assembly.
Then just go back in drafting, click on section view and then Ctrl + Tab (to switch window) to your 3D part or assembly and click one of the lines.
You can also make aligned sections if you use a "bended" sketch.
This works like a charm when you have skeleton parts when you can parametrize everything.
Also, @jackk, this works with any license I think.
Best regards,
Costin Ruja
Best regards,
Costin Ruja
